It is currently Wed Aug 20, 2025 7:22 am
PostPosted: Sun Apr 20, 2014 7:52 pm
The usual story....a possessed drill, an innocent fretboard. I had a small dent just right of the ab dot. I tried my tried and true LMI white and sawdust, but i think the glue as too cold and dried whitish. Now I have a white smooth circle.
I was thinking black CA and hope it takes the colour.
Any ideas?
PostPosted: Sun Apr 20, 2014 8:19 pm
With that much character and color variation in the board, I don't see any type of dust or other opaque filler as being your friend. Try some clear CA fill (making sure it's clean first), scrape, steel wool, and wax and see where that brings you.
PostPosted: Sun Apr 20, 2014 8:53 pm
First name: Chuck
Last Name: Hutchison
City: Houston
That's the only thing I dislike about LMI glue. It looks like white paint when dried if it's not warm enough.
Sent from my walkie talkie using Tapatalk
PostPosted: Mon Apr 21, 2014 8:28 am
City: Tyler
Unless it looks worse in person, I don't think I'd make a lot of fuss over it. Try the ca. When you get strings on, I can't see it being that noticeable.
PostPosted: Mon Apr 21, 2014 8:48 am
You need to use CA, not LMI's white glue. CA is what all the inlay folks use to fill the cavity around pieces. Use a fine grade of sand paper so you get small sawdust, make sure it's broken in so you don't get white flecks in it, pile it on and pack it in, flood it and let it dry. Level. It won't be completely invisible, but it will be a far cry better than white glue.
PostPosted: Mon Apr 21, 2014 12:37 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Maybe try wiping with some naptha first. Sometimes a glue line is just dust and will disappear with finish. If that works then switch to some lemon oil to make it last
PostPosted: Mon Apr 21, 2014 2:08 pm
Last Name: Sollod
I wondered why my LMI glue was turning white... I didn't know that it would do that in the cold. During the winter I do some less critical things since my shop is in the garage. The bottle was fairly new. I noticed the white color and was puzzled. Now I know. Thanks.
www.swiftcreekguitars.com
PostPosted: Mon Apr 21, 2014 2:10 pm
Last Name: Sollod
...also, I keep it in the refrigerator to make it last. Looks like I need to warm it up before I use it...
PostPosted: Mon Apr 21, 2014 9:37 pm
Ii you have some off cuts of that fretboard and can match the grain pattern you could drill with a 1/4' still and make a 1/4' plug to fit it and fill with ebony dust and thin CA (or a smaller drill hole and hand shape a plug) If not, Ebony dust and thin CA as recommended.
Try on scrap if you have enough offcuts.
PostPosted: Tue Apr 22, 2014 1:20 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Well, no. Ebony dust and CA glue in an EIR fingerboard will be pretty ugly. If you need to make this go away, excavate the previous repair, leaving an irregular border. (Don't remove any more than you have to.) Create some sanding dust from the palest portions of an off-cut (or a similar piece, if an off-cut is not an option). (Cut out lighter sections before sanding. Don't mix darker grain lines in with the lighter elements.)
Next, fill the void with medium CA, and quickly pack the glue with the sanding dust. Give it a minute or two, then flood with thin CA. Let it cure overnight, then level with a scraper.
If you want to take it to the next level, you can carve out some shallow channels in your repair that connect the darker grain lines. Fill these with CA glue packed with dust from the darker EIR, level, and the repair should be hard to spot.
